Originally Posted by BrianBlair
I'm going to be doing this repair on my van this weekend. I've got a few questions if one of you wouldn't mind:
1. I have the Dorman canister/ball mentioned multiple times above. My question is.....which direction do I want the inlet/outlet? In other words, should the outlet or inlet head through the firewall?
The Dorman part along with every other vacuum reservoir (assuming they DO NOT have built-in check valves or something similar) doesn't matter what you make as "in" and "out" The check valve you should be using determines what comes from the intake and which goes to the factory control system.
2. Just so we're clear, you're essentially just inserting the ball inline on the black vacuum line that comes through the firewall, however you decide to route everything. Is that right?
Thanks!
BB
For the most part that's correct. If you care to see another manner I've done this--using Ford factory parts instead--you're welcome to see this thread I posted in FTE's Tech Folder:
https://www.ford-trucks.com/forums/1...-controls.html That might be more than you want or need but 'tis offered none the less!
HTH
