Originally Posted by JWA
Along with the tank or reservoir proper installation and operation of the check valve is equally important. Good point on checking all hoses as any leak in one or more of them will mostly negate the reservoir/check valve assembly.
I haven’t look at the instructions of the kit you bought, but I assume you had to run a new pipe from the reservoir to the passenger footwell. Simply disconnect that pipe from the reservoir and put a pressure tester on it (very cheap to buy). If it leaks then you need to start looking at all the crap under the dash, if not you know it’s reservoir/check valve/vacuum pump etc.
I can’t remember the exact layout as I did mine years ago and made my own reservoir from PVC pipe, but you should be able to test it easily with something like this.
https://www.amazon.com/Automotive-Pr...-1-spons&psc=1
