Doing another run of T Bolts. Please email if you want a set. It’ll be 2 weeks from the time I place the order.
$165 shipped to you.
Includes:
1 set of 11 “T Bolts” which are 1/4-20 bolts welded to custom cut 1/8” thick, 2.5” diameter washers
11 nylock nuts and flat washers for the interior.
All 316 stainless steel.
Bolts are 4” long and you trim off what you don’t need for your application with a dremel/hacksaw or the like.
YOU SUPPLY THE SEALING METHOD OF YOUR CHOICE. You can seal them with butyl tape or a quality silicone caulk under the washer. As a yacht captain, my go to is 3M UV4000 fast cure.
If you’re repainting or bedlining your top, install T bolts AFTER it’s coated.
