Old 11-26-2022, 10:57 PM   #1
Dana 60 rear axle value
Hi all,
I have a 2003 EB350 U Joint 4x4 and I recently upgraded the rear axle from a Dana 60 to a Sterling 10.5.
I am looking for estimates for the value. I will most likely put in on my local Craigslist and FB Marketplace. I'm in the Phoenix area.
Dana 60
4.10 gear with LSD
Complete with spring perches, brakes, E brake cables, ABS, wheel spacers, U bolts. Also includes a 1350 U joint / 16 spline slip yoke.
SP55 is offline   Reply With Quote
Old 11-27-2022, 09:07 AM   #2
Unfortunately, your axle is a semi-float, which is not the most desirable rear axle.
Your axle really only has value to someone that has cooked their rear axle and is desperate to get one to get them back on the road. Or is converting a van to a 4x4 on a budget and wants that gearing.
The LSD and 4:10 gears has a value but if a guy wanted that rather than buying an entire axle to get that, they would just buy a LSD or locker.
I would say $400 to $450
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
Old 11-27-2022, 09:09 AM   #3
That's a semi-float D60 correct? I'm in Flagstaff and was able to sell mine to somebody that drove up from Phoenix but it took awhile.
Maybe somebody else can chime in but I'd start at $500 and go from there.
2011 VW TDI Golf for hwy fun
Old 11-27-2022, 11:51 AM   #4
Scrap value only for a semi-float IMO. They run about $350 from a wrecking yard, which would get a small premium because they all have exchange policies in case you buy a bad one.
The wheel adapters are probably worth more.
Old 11-27-2022, 03:43 PM   #5
Yes, it's a semi float. Thanks for the input so far. I'm not expecting it to be worth much.
Old 11-27-2022, 04:01 PM   #6
In the end I sold mine for $100. But the brakes are worth that if anything for a core return and also the emergency brake cable is a pricey item.
Old 11-28-2022, 07:12 PM   #7
I'm in Tuscon and have a Dyna 60 Full floater from a 1999 E-350 XLT with 170K miles on it. I purchased for my 1997 E-350, but it is not going to happen.
posplayr is offline   Reply With Quote
Old 11-30-2022, 09:29 AM   #8
^^^^How much? Has any work been done yet, brake pads, calipers etc?
I'm too far away but for someone close or highly motivated that might be good to know information.
