If you’d prefer something that doesn’t need to be attended too often, select a model that has a sink drain. Assuming you have a sink, it would just drain into your gray water tank. If temps are expected below freezing, I’d also prime the gray tank with a stronger solution of winterizer so as it drains the tank doesn’t freeze.
Lot of commentary out there (especially the marine industry) stating most of the dehumidifiers don’t function well when temps get real low.
I’ve used one of these in the cabin of my boat (and now in my van), and have had no issues with mold or smells developing (I’m hooked up to shore power all the time):
https://www.amazon.com/Caframo-Engin...7662241&sr=8-3
Edit: If we're forecasted for temps well below freezing for several days then i just run the Espar heater on the lowest setting.
