Originally Posted by CaptainVo
Blowing air clears the propane heater in my rig. Just need to open up the drain valve at the back left corner. I also pour whatever deicer I have on hand in the sink.
Where is that drain valve exactly? Does it empty out the hot water tank as well? Here's a picture of my hot water heater. Is this just the igniter?
Originally Posted by Bbasso
Possibly circulate some cheap vodka through your system to prevent any freezing.
Haha I'm about to cross the border, can't have it reeking like alcohol!
So I went under the van to try and find the stop cock by the water fill port. I couldn't find any at all but I did figure out what
all the external water lines are and made a schematic (first pic).
I guess all I can do is drain the fresh water tank using the fresh water tank drain pipe that goes through the floor, and with the water pump out of the shower/sink faucets. Then blow compressed air through the water fill port with all the faucets open and hope that pushes the rest of the water out of the pipes and water heater/water heater tank.
