Door Hinge Bolt Needed
Do any of you know what the specs are on the door hinge bolt that Aluminess provides with their spare tire carrier? Or where I could get them other than through Aluminess?
It's the stainless bolt that replaces the door hinge pin you have to knock out when mounting the carrier. I contacted Aluminess and was told the bolt is one they have customized to fit. Is that really the case?
I am having a similar carrier made for a storage box and need two more of the bolts...
'99 E350 EB 7.3L, 2WD, WeldTec lift, CCV Mid Top
