Originally Posted by 1der
A solution for weighting the legs would be to get a couple of 10 lb barbell weights and cut a slot in them to slip over the leg feet.
I primarily do pull-offs into National Forests and BLMs, so, the ground where I stop is not predictable if stakes will be able to secure down anything: rock, silt, sand, mud, etc.
Noticing that the image is from the Fiamma product site, are you using the
Fiamma anchoring straps?
I like the 10 lb barbell weights cut with a slot. I currently considering
canopy weights:
