Old 05-02-2007, 02:46 PM   #1
Flapping noise
I have been lurking around since this forum started and I thank all who have been so diligent in getting it up and running. When I drive my SMB (new 2006 Ford/garageable PH) at 62+ mph I hear a distinct flapping sound coming from where I think...above the windshield. Everything is latched down. I talked w/Jim in Huntington and he has no idea what I am hearing. Have any of you had this happen or have any ideas? I have an awning, and I thought maybe it might also be the antennae? Thanks for your help.
E250/RB/Garageable PH/Stowaway 2
Custom Interior
camptj is offline   Reply With Quote
Old 05-02-2007, 03:21 PM   #2
Can you adjust the sideview mirror before starting to see the awning or can someone riding with you see it through the mirror?
You might also temporarily secure whatever you think it might be and see if the noise changes, screw out the antenna (if it does) that kind of thing.
A photo of the van might help people have ideas better ideas. ops:
If you have a CB usually truckers will help as your cruising down the highway, but that's probably not a solution for a short stretch where you're just getting on and getting up to 65 to test.
Old 05-02-2007, 08:03 PM   #3
calclimber's Avatar
Mine also makes a flapping noise, I think it may be the propane,waterfill door on the drivers side flapping in the breeze. :roll:
Craig 2005 eb 50 PH 4x4 V10
Quality doesn't come in a twist off
Craig
05 EB 50 V10 4x4 Baja Tan
calclimber is offline   Reply With Quote
Old 05-04-2007, 10:14 AM   #4
Interesting thought. Mine doesn't make a flapping noise, but I have no propane. Why not duct tape the fill doors and try to replicate? That's how I found out that the large incut inside for the water drain (behind the fill line) shoves TONS of air into the van over about 60 mph; duct taping over that stopped it.
Come to think of it, maybe that's it. I'm talking about the big rectangular hole cut on the inside of the outer van wall, where the drain line for the water fill is. When I'd hit 60+ MPH, I'd get a strong breeze coming into the cabin (and could hear the road) right behind me. Turns out SMB screwed up some dimensions on my interior, so the plastic shroud that covers where the seat belt is doesn't stay attached. Thus, that became the path of least resistance, and it was like having a vent on full blast, made up of air from the outside, when I'd hit about 60 mph. If you have the same issue, then perhaps the air being forced into your van interior is finding a _different_ path of least resistance, is moving up through your interior wall to a higher point, and perhaps that's causing some of the insulation edges to flap!
Regardless, I tested out and confirmed that this was the source of my air infiltration by covering the entire hole with duct tape, then hitting speed again.... no air blowing inside from the outside! This might be your issue.... Try it, and report back...
2006 RB50 6.0 Diesel
SMB 4WD
Amsoil
kzemach is offline   Reply With Quote
