03-21-2012, 12:08 PM
Gas Gauge Stuck/Broken
My gas gauge is stuck at max full. Any ideas what the issue might be, and how to fix it?
2001 Ford E350 extended body. Not sure what size gas tank it has, previous buyer told me it was a 50 gallon tank, but I've never been able to get more than 39 gallons in it.
03-21-2012, 04:55 PM
Re: Gas Gauge Stuck/Broken
Any idea what kind of van we are talking about?
Year, Make, Model?
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
03-21-2012, 05:06 PM
Year, Make, Model?
Edited to include. That would help!
03-21-2012, 05:08 PM
Is that a rear tank, or a side tank?
6.0 PSD 4.10 Posi
2015 VW GTI
Leaving CA for WA
03-21-2012, 05:57 PM
Not sure I know the answer to that. The filler tube is between the drivers door and the rear wheel, does that help? How do I tell the difference, and how does this make a difference figuring out what is causing the guage to stick?
03-21-2012, 06:18 PM
Probably doesn't make any difference, I was just curious. A ~50 gallon tank was rear mounted at least on cutaway vans. When you added 39 gallons, was it empty (engine quit from no fuel) or just running low? Just curious.
Does the gauge drop when you turn the key off? If not, the gauge is probably bad. And that may mean an instrument cluster from a wrecking yard.
If it drops when the key is off, then either the sender or the wiring is the culprit. And usually that means you have to drop the tank to get to the sender.
6.0 PSD 4.10 Posi
2015 VW GTI
Leaving CA for WA
03-21-2012, 07:52 PM
The sending unit has a mechanical float. The float can be bent which will cause it to stick in one position. Our new van had this issue.
2009 E250 RB 5.4L "SilVan"
03-22-2012, 12:48 AM
If the wiring would be damaged, it would be on empty and not go up, at least like on my 2009.
03-29-2012, 06:41 PM
Generally it is a float or pickup issue. Could be a wiring short which should be checked first. General fix is run the tank fuel down, lower tank (google or look it up), replace sensor/fuel pump assy. For gas the part runs ~$400.....You might get lucky and find wiring issue or a stuck float that is fixable.
Pac NW and warmer places
2006 E350 EB Elect Top 2WD
03-31-2012, 07:31 PM
The gauge drops when I turn off the key, so I guess it must be the wiring or the sender.
