Grey recirculation valve
That valve allows the tank to be filled from the water fill on the exterior of the van, one way opens to allow water in, the other way closes the loop for the water to be pressurized and run through the pump to your faucet. It sounds like you might have it in the open position.
Fill the tank and put it into the position that pressurizes the line and runs out the faucet, let it run for a bit to get all the air out, close the faucet and it should hold without the pump cycling, if it does, you might have a crack in the line or a fitting somewhere.
