Old 04-24-2020, 12:09 AM   #1
CDACamper's Avatar
Help-Water Heater Bypass Valve
I have a 2001 E 350 with stock SMB water setup including a Suburban gas water heater. I have no idea how the bypass valve works. Is seems like the water heater is not filling and want to see if anyone has this setup and what the position of the valve should be for normal operation. Below is a picture. Should the valve be horizontal like in the picture up pointed up verticle?
______________________________
2001 E-350 V10 EB50 Penthouse
4X4 Quigley
CDACamper is offline   Reply With Quote
Old 04-26-2020, 12:18 AM   #2
CDACamper's Avatar
I found out the answer to my own question so I thought I would post the answer for others with this setup. There are actually 2 valves, the one circled in the picture above, and one on the fitting coming out of the top of the tank. For normal operation, both valves should be in line with the fitting going into the tank. With both valves in this position, all is operating properly. If winterizing the hot water tank, you put both valves perpendicular to the tank fitting and it keeps antifreeze out of the hot water tank.
4X4 Quigley
