Look around for a batteries plus, they carry rebranded East Penn/Deka batteries as Duracell RV/Marine deep cycle AGM, they’re sealed units and can better withstand extreme temp changes and discharges without damage. You’ll want to match the size, if it’s a big honker, most likely a 4D.
You’ll probably want to address the charger issue by getting a bigger charge unit, or get a charger/inverter unit so you don’t keep running into the same issue.
I can’t remember if you mentioned if you have solar or just the pre-wiring, add it if not, it’s the best way to keep things topped off and your battery happy if your rig sits outside between trips.
