Old 01-08-2022, 05:08 PM   #161
Just weighed Moby, 2010 EB45 w/Quigley 4WD. Stock bumpers and 1/2 tank of gas, no water. Empty with just me in it:
Front 3760
Rear 4780
Total 8540
2010 V10 EB45 4X4
new2tx is offline   Reply With Quote
Old 01-13-2022, 07:49 PM   #162
2014 V10 EB50 Quadvan, full gas, no water or beer
Front 4360
Rear 5680
Total 10040
PNWschusser is offline   Reply With Quote
Old 01-31-2022, 08:48 PM   #163
bebopsteve's Avatar
2005 SMB 4x4 EB-50 w/full tank of fuel and loaded with 4 bikes, tools, food, bikes and camp gear…
4400# front axle
7000# rear
9 mos later, seized a rear axle bearing and ground inside rear end, pulled axle shaft out and had some serious thinning of the shaft diameter so converted to a full floating rear axle shortly thereafter. Be very careful of your weight if you’re still running a semi-floater!!Click image for larger version
ID:	42697 Click image for larger version
bebopsteve is offline   Reply With Quote
Old 01-31-2022, 10:39 PM   #164
pjpvi's Avatar
4400# front axle
7000# rear
9 mos later, seized a rear axle bearing and ground inside rear end, pulled axle shaft out and had some serious thinning of the shaft diameter so converted to a full floating rear axle shortly thereafter. Be very careful of your weight if you’re still running a semi-floater!!Attachment 42697 Attachment 42696
Attachment 42698
That looks a lot like my van and axle back in the day. Glad you caught it before it snapped.
Phil
- 2005 EB50 6.0PSD - SMB 4x4
Old 02-06-2022, 10:26 PM   #165
jeff.depaul's Avatar
Rear axle replacement
4400# front axle
7000# rear
Attachment 42698
bebopsteve, just curious what did you replace your rear axle with? I am looking at a Sterling 10.5 full float - currently have Dana 60 semi in my 2010 SMB.
jeff.depaul is offline   Reply With Quote
Old 02-07-2022, 10:04 AM   #166
shenrie's Avatar
^^^ i got my 10.5 sterling from a 2005 f250. was able to find one locally with the same mileage as my van, just happen to be the right gearing (4:10), and it had a trac lok lsd. by the time i got my core charge back and sold the lsd from my semi float i was only into the rear axle about $150.00.
LiamMobile
Shyll
Rex
Tomboy
