You did not state what your temps were. Instal a mechanical trans temp and a water temp or more...
I have temperature gauges for Trans, water, Oil. Then I have oil pressure, Volt meter, boost meter, Tach, and EGT temp gauges. They were the first things I put in and a bigger deeper aluminum trans pan.
Next what is your gear ratio?
How much does the van weigh loaded. Important questions that need answers in arm chair diagnostics.
