Originally Posted by JWA
OMG that'd ruined my entire year!
I wonder if you sprayed a circle of that material around the parked vehicle would that work to keep critters away? Does it evaporate away and lose its effectiveness?
Its a liquid concentrate of capsaicinoids so yeah it would eventually lose its potency, how long it would take is anyone's guess. I would think it would depend on surface it was applied to. If it was in a enclosed garage/outbuilding/warehouse it would likely last significantly vs on a open driveway. But if you are in a enclosed storage area, traps are likely a cheaper and more practical solution.
If it's just a drive way, I would gently spray to area that have some shelter to the elements (undercarriage, engine bay). You could probably improvise a similar compound with cayenne pepper/water since bear spray isn't exactly cheap and once you use it, its pretty much done.
