Old 08-09-2020, 03:37 PM   #1
Mounting Solar Panels on popup top
I just purchased 4 100 Watts Renogy solar panels.
Need advice on how to install on top of SMB pop up top.
Can I drill into the roof and use the Z-mounts that came with the panels?
Don't know what material SMB popup top roof is made of. Can it be drilled?
Should I use screws or bolts?
If yes, what about sealing against leaks?
OR, do I need to install a roof rack and mount panels to the track?
Please help!
wanlarry719 is offline   Reply With Quote
Old 08-09-2020, 03:53 PM   #2
Twoxentrix's Avatar
Think you should first start with reading Scalf77's Thread
https://www.sportsmobileforum.com/fo...ing-21140.html
These include discussions on mounting (more Threads available using the search function):
https://www.sportsmobileforum.com/fo...ler-25863.html
https://www.sportsmobileforum.com/fo...vhb-24863.html
https://www.sportsmobileforum.com/fo...amp-24344.html
Old 08-09-2020, 06:53 PM   #3
Thanks. Lots of useful info
Old 08-09-2020, 08:33 PM   #4
[ATTACH]34961[/ATTACH
Here’s my solution. Yakima tracks with 80/20 cross rails
rizzabove is offline   Reply With Quote
Old 08-10-2020, 09:50 AM   #5
Thanks. That looks great
