Lots of good info-thanks!
Black exterior is out there...esp in passenger vans. The interiors are either grey or tan.
Looking around lately it seems like a variation on the old Henry Ford adage: "You can have any color van you want-as long as it's white!"
I'm hoping to find grey cloth but would do tan if that's all I can get. Exterior color is more important.
You can add tow mirrors easily. The F-series look like they will fit but they won't, but E-series tow mirrors are easy enough to find. OEMs are typically better than aftermarket......mostly just because they shake less when driving.
I'm just so used to the wide view I get from them in my truck and the ability to scan the entire highway behind me while driving. I hate driving vehicles with regular sized mirrors.
The 2008 vans have the new front end but the old dash..2009+ have new dash/front door panels too.
Yes-definitely prefer the 2009 and up dash and door panels because they have more of the feel of an '11-'16 Super Duty.
The chrome and black grills swap no problem, and you can keep the XLT headlights...although they are pretty average.
Good to know. I know that the XLT lights aren't great-they're probably not too different than the '11-'16 Super Duty lights which aren't great either. In any event they're better than the sealed beams in that I can at least try some different LED bulbs plus I just prefer the look.
Rear wheel adapters no problem, 1" on the front may not be feasable.
I was wondering about that-if its not possible I wonder if 2WD Super Duty hubs would swap onto E350 spindles?
There are two common lift kits for 2wd vans; Action Van and Camburg....in case you are thinking of lifting.
I will definitely check them out-thanks for the tip as I was not sure if there were any lifts available for 2WDs. Not sure if I want to go that route but good to know that its an option.
