01-01-2021, 02:45 PM
Phil, bought a 15 gallon to fit beside the existing tank. Was wondering how you connected your two water tanks. Just a single connection making it in fact a single tank, or did you isolate with valves? I feel like I want to isolate in case one springs a leak or is contaminated some way. Wonder if I am being too anal about it. Would be much easier just to connect the two and be done with it.
Tony
2006 Baja Tan SMB 4X4 RB50 PH 6LPSD
Photographer in Belize, Central America https://tonyrath.com
01-01-2021, 05:52 PM
Originally Posted by 86Scotty
My world was changed when I started using half gallon pump sprayers for hand and dishwashing. There is a LOT of water wasted on these two.
I've noticed the same thing about coffee. Sure does take up a lot of water.
https://www.harborfreight.com/05-gal...hoCJBMQAvD_BwE
I'm confused, how do you make coffee with a half gallon pump sprayer? [emoji16]
01-01-2021, 07:06 PM
Hey Tony -
Mine are separate. I can fill the original tank from the new tank if I need (in the case where I don't have access to a pressurized hose for instance) but can't fill the new tank from the original tank. I could have designed it such that either tank could fill the other but I concluded that it made things more complicated and if I have a pressurized hose I could easily fill both independently.
That's the long way of saying they both tie into the same distribution line and each have their own pump.
Hope that makes sense ...
Phil
- 2005 EB50 6.0PSD - SMB 4x4
01-02-2021, 08:26 AM
My post was in response to Arctictraveler, post #8. I've noticed that coffee uses a lot out of your water tanks. Half gallon a day for me, just for coffee.
Separately, you can use a hand pump sprayer for hands and dishes and not compromise your water tank supply. A hand pump garden sprayer will do a lot of hands and dishes on one fill.
01-02-2021, 10:58 AM
... A hand pump garden sprayer will do a lot of hands and dishes on one fill.
Geeeez - and now I feel really stupid! We bought a Water Port for that specific reason (3 gallons goes a long way for washing stuff with a controlled spray head on a length of hose). Could have saved A LOT of money with your recommendation of a garden style pump sprayer from Home Depot.
01-04-2021, 08:26 AM
I really like the half gallon sprayer idea they are on my sorry list. I was just being a goof with the coffee comment.
01-04-2021, 09:58 AM
Originally Posted by Belize
I want to expand my onboard water capacity from the standard 10 gallon tank to 20. I want to get another plastic tank that will sit right beside the current one. The size apparently is not standard, so will need to find a custom made tank. Can anyone recommend where to get a tank made (21.6” x 9.6” x 12.5”)? Thanks!
If you haven't got one yet I may have just what you need. I bought one near that size but a bit smaller for mine but did not install. LMK if you want measurements etc.
01-04-2021, 02:51 PM
Isn't that really just another way of saying you drink a lot of coffee?
For me the big drain is making pasta.
N8SRE
01-04-2021, 05:48 PM
#20
