Originally Posted by 1der
I am in the same category with the DW1504 numbering. Bummer, I had the original /OEM glass replaced about 2 years ago after a chip propagated all the way across.
Well that happens---I'd not be in business otherwise.
Thanks for the effort though!
Originally Posted by ScrapIron
Is there an issue with the DW windshields? I can probably find what youre looking for at the local salvage yard. They have tons of junked vans in that specific year range. Are you just needing the numbers and pictures or are you needing a windshield?
I need the logo images in order to assure what I'd order from the dealership would have the same features I'm seeking, ideally a DW1292 GBY. However because that number is no longer available the generic shape of the 1992 > 2013 E-Series is only available in the DW1504 GBY or DW1624 GBY which are NOT what i'm seeking.
Here's what I want to NOT have on a new windshield:
The area described in greenish is the typical rear view mirror mounting "button", area described in magenta is a black spot intended to block direct sunlight from causing the adhesive holding the mirror "button" to the windshield to over heat----that action can cause the entire rear view mirror to fall off the glass.
Because I can safely remove just the mirror "button" when just that black spot remains it distracts the helloutta me.
Its so bothersome I'm willing to pay just about 3X the cost of a generic replacement part.
ScrapIron if you could find just the numbers and maybe an image of the rear view mirror mount (with or without the mirror in place) that would be an absolute godsend! I'd be more than willing to compensate you for time spent chasing this wild goose for me. Thanks so much for that idea and offer!
