Originally Posted by kevman
265/75R16's on -6mm offset rims will rub slightly on the stock front bumper valence and pinch weld at full lock.
Blanket statements like this aren’t good. You should specifically state “on my van” in front of the quoted text above. There is so much variance in the vans (even more so on the 4wd converted vans) that stating what you did then having an uninformed person buy stuff on this statement would put you in a position of wasting their money. Do you have the lift the op is planning on using? Another variance... plus there is no industry standard to tire sizing, since your 265/75r16 tire could be an inch narrower and a .5” less overall diameter than the op’s same sized tire.
It’s a pita, but op should take everything read with a grain of salt and use the info in these types of threads as a rough guideline. If your trying to fit the most rubber as possible, your best asset is a friendly wheel and tire center willing to help test fit a few different sizes to get you where you want to be.
