Re: Our 2015 Ford Transit is now a Sportsmobile!
Originally Posted by BillPa1
The Benz has four wheel drive with low range. Does the Ford Transit have four wheel drive with low range?
I believe that the Quigley 4x4 conversion will have high and low 4x4 and probably has manual locking hubs. They are supposed to be using the same basic setup as the newer F150 pickup.
