Old 03-18-2020, 10:42 PM   #1
Penthouse top reseal
I have some leaks in my penthouse pop top and want to reseal the bolts.
My question is in regard to the butyl seals (discs) I have seen people use to seal under the large washers.
Is this a rubber only piece, or is one or both sides of it sticky? Like a butyl tape you would use to seal a door vapor barrier or window to the body.
I had ordered some materials I thought I saw listed in another thread and what I got I wasnít expecting. It is a rubber type pad that is not sticky. It doesnít seem to compress a lot and Iím wondering if this will seal tightly.
What are you guys using under either the regular bolt and washer set up or the special poptop t nuts?
Thanks a lot.
Old 03-22-2020, 11:56 AM   #2
Bump for some info.
Old 03-22-2020, 01:12 PM   #3
BenJJ's Avatar
I bought some big washers and put butyl tape underneath them
BenJJ is offline   Reply With Quote
