Converting to electric is $$$ if SMB still does that on older vans.
Your springs need adjustment. A properly adjusted roof goes about as easy as it comes down, just like a properly adjusted garage door.
Do you have anything on the roof?
Where are you located?
Do a search here for penthouse spring adjustment there are a handful of threads.
The method I use requires a $20 Harbor freight come-along, a motorcycle tie-down and a 28" long piece of 2x4.......and a phillips screwdriver to undo the upholstery.
