Originally Posted by Justgosurfin
Thanks. I’ll measure the blocks the previous owner had behind the helper springs but I believe they were about 2.5-3”. PO also had 1 link out. I think I’ll try that then potentially go to two.
I did finally find my plates and painted them. I’ll see if there’s a way to through bolt them down.
If you through-bolt them down getting them off after an interior build may be challenging. I used Riv-nuts in the roof sheet metal, then subsequently went to a 2x4 piece of 1/4" AL angle (from McMaster). This allows fastening the short leg of the angle to the vertical part of the channel for a much more robust design.
If you really crank up the spring load those plates flex easily since one long end is sitting out there in the breeze.
I'm planning on further investigating using a combo of gas springs and the helper springs, and from earlier measurements I'll likely cut my helper springs down from 24" long to 12" long to double the spring rate. A couple of EB tops that I've played with had 12" long springs and those went up crazy easy (with nothing on the roof).
