Are your panels centered? If I remember correctly, with the SMB manual pop tops, if there’s off center weight up top, it will come down and close off kilter. It helps to center the weight as much as possible.
The other thing you may have to do is adjust your spring tensions if you haven’t already done so and add larger pre load blocks. There’s a few write ups on the process, a PITA, but helps with lifting when adding weight.
