Originally Posted by rsboebel
Is it a danger sign that this has only been driven 5k year or is this no big deal for econolines?
I missed this...
Anything with old vehicles... it's the rubber that wears out. Gaskets (Doors, windows)... We had most/all of the hoses on the engine replaced two years back or so, not that anything was failing. Preventative measure.
A lot of these 4th gen vans have a rust spot that's at the bottom lip of the drivers door... If it's there it will be apparent, I've seen several vans with it. I think it's mostly people getting into/out of the van with rocks in their shoes or are otherwise wearing the paint down there, and over 20 years it starts to rust.
The one thing that did go out was the rear heating lines. For vans equipped with the rear AC/Heat, there are lines that run the length of the body down the drivers side of the vehicles... Ours had a couple of pinhole leaks back in.... 2007 or so? 2006-2009? I think that was more of a 'random nature' replacement than a routine breakage.
