Originally Posted by BrianW
The GTRVs were all built on E150s, which IMO are undersized for the weight of the build.
The "Hay day" of GTRV seems to be right around 2000 or so and most (but not all) were on E150 chassis. You are not alone in your opinion - I am told that at some point, GTRV stopped using the E150 platform for that very reason. Interestingly, I once had a 1982 Sportsmobile on a Chevy half-ton chassis with 305 - I had a lousy experience with it, only marginally better than the 1974 VW Westfalia with 1700cc it replaced. Compared to both, the GTRV top is very low - same height as a stock van so is more often garage-agble. However, I prefer the slight increase in interior height of the SMB when top is down. Everything is a compromise I suppose.
Thanks for all the tips.....
Peter
