Originally Posted by Fremebe
1. I want to understand the two parts that are on the inside of the van. The one on the floor I assume contains the blower and the motor. Is this true? I also thought there was a part that removed heat from the van. Is it also contianed in this unit.
The blower unit has the evaporator in it. It's a radiator looking thing inside that extracts the heat from the van.
2. One of the things I hated about my design was that all there vents were next to each other. I would be freezing on the back couch while the rest of the van was hot. I assume I can simply replace with longer hose and reverts the air flow accordingly.
Yep. You can redirect those hoses anywhere …*or even put a tee and redirect multiple places! Espar makes some cute little butterfly valves that work with 60 or 90mm ducting, and have a cable for remotely controlling them:
https://www.heatso.com/espar-eberspa...y-branch-60mm/
3. I understand the “hosed-blower?” unit has tubes exiting the van. I believe they may be drainage tubes. I am replacing the floor and need to understand if I can simply suspend the unit and slide a new floor under it or is removal so complicated best to just add a cut out. I want to remove as much floor as possible.
On mine, they literally just poked through the floor. You can lift the whole thing up. You want to make sure they'll stick all the way through whatever flooring you put in, but they're just there for condensation to drip out of.
4. What is the grey box—a relay switch box I assume? I need to disconnect the box from the back panel to remove. Can I simply remove the screws—keep it intake and then screw back on to the new wall or is it a lot more complicated.
It's not any more complicated. It's a bunch of relays that control things based on thermostat, fan blower, and whether the van's on (depending on your exact configuration) but you should be able to unplug everything and plug it back in wherever the wires reach to (or even extend them).
5. As you can see I have to remove the switch and the thermostat. Best option remove wires but afraid of messing anything up. Other option cut around (not best for reinstall). Is this easy to disconnect/ reconnect?
Easy to disconnect / reconnect, just mark your wires!
6. Lastly the unit other than a thermostat has not failed me and has had limited use. Seems senseless to replace since working fine. But have had a lot of frustration with the inability to have this unit serviced or getting any info on it. Since sold to fleets not been able to find AC people who are willing to even discuss it. Danhard the company real hard to get call backs or speak to anyone in technical service. Respectfully I do not think they are set up to assist consumers, which makes this product challenging to own.
It is 9.5 years old but working fine. Thoughts about just keeping it in my new build.
I kept mine, and figured out how to fix it myself, but haven't yet decided whether that was the right call
