Old 02-07-2011, 04:09 PM   #1
louie's Avatar
Quigley Chevy conversion
How about this question: Do quigley conversions come with leaf or coil springs? I'm trying to figure out what kind of 4x4 quigley set up the 2000 GM might have. Owner drove it to the factory when brand new, said give me the standard 4x4 conversion and drove it back home. Doesn't seem to have much knowlege of what all came with the conversion. What would be the depreciation of a quigley conversion done in 2000 and has had 60000 miles put on it since then?
I've enjoyed reading the posts. Many thanks.
Always looking...4x4 Van 19ft or shorter. Sleeps 4 - two together, two separately; 4 forward facing seats with shoulder seatbelts, interior shower, water heater, 110 power, sink, aux. heat, aux air conditioner, aux. battery, generator - all at a price a school teacher could afford...help me Obi-Wan Kenobi you're my only hope.
louie is offline   Reply With Quote
Old 02-07-2011, 06:02 PM   #2
Re: Quigley Chevy conversion
The 'standard' Quigley would be the same system as GM pickups - IFS with torsion bars. They have neither coil springs nor leaf springs. But, they also have a ride height about the same a 2wd van.
Not sure if that holds true for 2000 model year or not.
Old 02-07-2011, 09:09 PM   #3
dhally's Avatar
I'm pretty sure that Quigley used to install a solid front axle on the Chevy vans. Lately they install an IFS with torsion bar front springs. However I don't know when they changed from solid to IFS. A quick picture should tell the story. If the van has the solid front axle it will sit a lot higher than the stock van
2009 E250 RB 5.4L "SilVan"
Old 02-07-2011, 11:38 PM   #4
I *think* it was around '06 when the IFS setup first appeared. Before that it was only solid axle.
This is an '06 Chevy van with Solid Axle and coil springs:
It's a Ford Dana 60 front axle, with Quigley trailing arms. Newer Chevy Quigleys are all IFS. The was some overlap where both was available. I seem to think at one point the Chevy Quigleys had leaf springs, but I'm not 100% sure it was a actually a Quigley I was looking at.
on-edit. I found some info that in '99 Quigley used 56" double tapered leaf springs for the Chevy vans. I do not know when Quigley went from leaf to coils on the Chevy vans. A call to Quigley can probably find you the transition point.
Old 02-07-2011, 11:50 PM   #5
Found it.... '00 Chevy Quigleys are leaf spring. Here's a good video:
http://wn.com/MW_2000_Chevrolet_Expr...gley_Road_Test
Old 02-08-2011, 09:05 AM   #6
I have a 2000 and it has leafs with a dana 60 solid axle. rides nice. I picked mine up for $8K with 160K on the big block. runs great!!
racrx451 is offline   Reply With Quote
Old 02-08-2011, 05:35 PM   #7
BTW - nice thing about leaf springs is it is a simpler setup, and probably not affected by some of the problems that coil-sprung Quigleys had (like track-bar bushings going bad and causing death-wobble). And.... I bet you can get upgrades from U-Joint since his conversions are also leaf springs over Dana 60 axles.
Old 09-23-2011, 03:15 AM   #8
Frist Post here!
I currently own a 1998 GMC ext Savana 3500, and want to know if anybody has any pics if there
4x4 setup for this van. I plan on fabing my own, but would like to see how its done by the pro's (Quigley, SMB, etc). Thanks
Luke928 is offline   Reply With Quote
Old 09-23-2011, 03:20 AM   #9
Anybody got any pics of there 96-2002 Chevy GMC 4x4 front ends.
Old 09-26-2011, 09:50 PM   #10
Originally Posted by Luke928
Frist Post here!
Rules from Homebuild, apply here as well:
Please do not use this section, or any part of this site to publicly post or request information for the purposes of copying any manufacturers’ designs for the purpose of duplication.
