Originally Posted by DevineIntervention
I’m following this one because I’ve tried to come up with a way to hang curtains from those locations on my 2014 E350. The combination of 11mm x 1.25 TPI isn’t available any place I’ve looked. I’ve tried the bolts I removed with a 7/16-20 nut and they didn’t work (unless the nut at Home Depot was buggered up). ]
And herein lies the problem. Just did the math and 7/16x20 is roughly 11.1 x 1.27 so this leads me to believe the bolt is actually 7/16x20. Which, as I mentioned in my first post is too loose.
I'll pull out my full metric and standard tap and die set in the next week or two and see if I can find a tighter fit.
For now, I have mudguards to make. ;-)
Jeff
