05-27-2014, 11:03 AM
#51
Re: SMB Ford E-350 Cut-away w/fiberglass body
Also, it looks like Aluminess is finally updating their rear bumper to incorporate LED brake and backup lights.
I had them add some holes in mine for standard 4" round truck lights... The bumper angles down a little more than I might like where I have the LEDs, but it's better than nothing.
05-27-2014, 11:18 AM
#52
The angle could easily be fixed with some light buckets like they put on the front bumpers.
05-27-2014, 02:53 PM
#53
Originally Posted by carringb
.....cut.....
Maybe Ford will try putting a new cab on the F53/59 chassis? The bottom end of the F59 already overlaps the E450 stripped chassis. Even if they do, I think that would be several years out still, so SMB has some time to make back their investment before needing new molds.
.....cut.....
Didn't GM do something similar with a previous generation van? Can't recall details but it seems they used a tilt-forward front hood and partial fenders to accommodate the larger engines and power demand. Will look it up out of curiosity when I have time.
Regarding all your other points I get what you say but don't see it making much business sense for such a short period. Not unless the volume is huge -- and it won't be. It's not that high with current model.
Doesn't RoadTrek make a fiberglass body for GM van that is very similar in concept (except for 4WD)? The idea was to make a larger and wider van. And from what I can tell the volume didn't materialize to the level they suggested in early advertising. Large Sprinters took care of that.
Assuming 2019 is correct, and that it takes a while to go from prototype to production, and that many buyers won't buy at end of life cycle, I just don't see them making much money from this venture. I own and like an Econoline just fine for what it is, but business is business and wouldn't invest in this fiberglass project. Too much risk for limited upside.
05-27-2014, 03:24 PM
#54
.....cut.....
.....cut.....
roadtrek 210 is the model you talking about . it's still being made
gerry
05-27-2014, 04:33 PM
#55
Yes, that's the Roadtrek model I was thinking about. Not an extremely high volume item as far as I know.
Regarding Ford options to mount a Transit cab on a heavier-duty chassis, the Chevrolet van I was thinking about was from the mid 90s. And if I recall correctly the base van was semi-unitized also like the Transit.
As I recall the nose was fiberglass and tilted forward for engine access much like some larger trucks.
05-27-2014, 05:06 PM
#56
Yup. They took the cab from the Unibody G-series, bolted it to the P30 stripped chassis, and added a fiberglass hood. It was not a success, mostly because the P30 had TERRIBLE driving dynamics. It had about as much steering precision as a rudderless sailboat, and a ride that was floaty and harsh at the same time. And the interior was leftover from the 80's.
The newer TopKick 4500/5500 followed nearly the same formula, sticking the Express cab on a MDT chassis with a tilt hood. It had many of the same flaws (to a lesser extent), however it did sell well with a much lower price point than the E550. But GM lost $10,000 on every one sold, so shuttering the line was required as part of the restructuring.
05-27-2014, 06:59 PM
#57
I think it's highly likely a T-450 or T-550 cab or cutaway chassis will have to follow same formula, just starting with superior equipment. That it didn't work well for GM doesn't preclude a Ford success in my opinion. A 4X4 version may even be possible if based on F-series chassis.
Back on topic -- I'd rather see someone adapt a Transit body shell on top of a modified F-350 4X4 chassis (or similar) than make a fiberglass cutaway body. It would no doubt cost more but it would be worth it if off-roading was what I was looking for.
12-21-2014, 04:53 PM
#58
Anyone have any updates on the cutaway sportsmobile, or the transit?
05-03-2015, 06:56 PM
#59
05-04-2015, 08:19 AM
#60
they just keep getting uglier
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
