Old 08-14-2022, 01:56 PM   #1
jeff00seattle's Avatar
Question SMB RB50 Penthouse's under trim: Repair Segments?
Hello
Started the following thread: SMB RB50 Penthouse's under trim: Replace?
Sportsmobile does sell a trim and rivet kit for complete trim replacement, ~$250.
However, with the pop top shell 20+ yo, I am reluctant about replacing the trim, I might crack the fiberglass replacing the rivets.
Possibly a recommended way to repair only the damaged segments of trim that are split, instead of replacing the entire trim?
Thank you
Jeff in Seattle
2001 Ford E-250 RB50
jeff00seattle is offline   Reply With Quote
Old 08-14-2022, 03:47 PM   #2
Wow that seal at $250 seems awfully steep. I happily paid $100 on Black Friday from Sportsmobile a few years back. Does anyone have an alternative source?
Coloradical is offline   Reply With Quote
Old 08-19-2022, 11:52 AM   #3
Yes, I agree this price is steep.
That is another reason for seeking a patch solution, instead of replacing the entire trim.
Jeff in Seattle
Old 08-19-2022, 06:04 PM   #4
Greetings Jeff00Seattle -- can't promise this item would do tje trick for you - but check on something like this --
https://www.amazon.com/Trim-Lok-DD12...31771247064bf5
It looks like something that "might" work - and a bit cheaper -- copy and paste --
Tags
pop top. penthouse, trim
Hooch
Hoooch
The Yeti
TexGX
