Old 08-01-2024, 04:48 AM   #1
JFlo's Avatar
SMP Poptop frame failure
Friends,
The steel frame of my SMB poptop has failed just behind the driver's seat. Wondering if anyone else has experienced this and how it was repaired.
Here are some pics:
JFlo is offline   Reply With Quote
Old 08-01-2024, 05:11 PM   #2
moorefc's Avatar
Where was it made?
This is a good question for Sportsmobile. Have you tried?
Its been a long time since I accessed the front, but I don't remember the bolt area...
From your description, did the bolt pull thru the top, or what failed?
I will also say haven't seen any comments about that as a roof issue.....
Pac NW and warmer places
2006 E350 EB Elect Top 2WD
moorefc is offline   Reply With Quote
Old 08-01-2024, 05:20 PM   #3
JFlo's Avatar
SMB North installed it.
The forward lip of the frame fractured and failed. The last picture shows the piece that broke off. It held the frame in place with one bolt to the roof of the van.
I emailed SMB and got an immediate response. They came up with the same solution I did. I used a 2" piece of 12 gauge angle iron to secure the frame back to the roof. Here's the result. Fingers crossed this does the trick. I'd rather not have to replace the entire frame.
Old 08-02-2024, 07:15 AM   #4
I hope the fix works! It's been a good while since I had an SMB pop top apart and my memory is fading so I was reserving comment.
Also, just so you know, SMB pop top frame failures are very rare. I don't remember but a couple being spoken of here in the last 10 years. Support bars bending is the most common failure but still not necessarily common.
Glad you found a solution
Old 08-09-2024, 11:09 AM   #5
Similar failure
My 2004 failed around 2010 and included cracks in the roof sheet metal. Sportsmobile repaired it under warranty.
PatO is offline   Reply With Quote
Old 08-09-2024, 11:38 AM   #6
ctb
ctb's Avatar
Send a message via AIM to ctb
Good to hear SMB North was a call back ASAP....they are running smoothy even w/o Nancy N the SUPERSTAR...hope it all works out and your back to popping!
Ps GREAT pics and explanation for us all to understand/see your problem...
'23 Telluride
'02 Lexus 430 LS 'The Diplomat'
'24 Thor 25.7 Vegas
345 John Deere Rider LM
Old 08-10-2024, 06:29 AM   #7
Wait, I thought she came back or that her leaving was a rumor. Did she finally retire?
Tags
failure, frame, poptop, rail, smp
Priscilla
DocMP
Vanna
gahamby
