02-24-2018, 02:43 PM
Originally Posted by 86Scotty
That kit has some really great uses but this one might not be the best use. I think the push in fasteners are better. There are a LOT of em and they can be reused if removed carefully and not oxidized or otherwise destroyed. Then again, I don't guess anyone is pulling/replacing this seal very often. I've seen two 20 plus year old ones that were fine.
I concur!
Also, as another point to ponder with these true plastic rivets:
Be sure you want them installed when ya put 'em in.....because getting these rivets back out involves drilling their center out. Not difficult, as they're plastic, but for the sheer number of them on something like a penthouse seal.....
Mike T
___________________
'95 Ford E250 RB30 PH
02-27-2018, 12:17 PM
Thanks for the advice all...will report back when I'm done with the project.
02-27-2018, 02:51 PM
Not necessarily for this exact scenario (although maybe, I didn't have time to really look), but I've used this place in the past and they're a wealth of helpful retainer clips and fasteners. A lot of them are the exact OEM replacements you'd get from the dealership. I've found a few things here that I wasn't able to find anywhere else:
ClipsAndFasteners.com - Automotive Retainers,Clips and Fasteners
2005 E350 4x4 V10
09-11-2023, 10:42 PM
Before destroying at least the first one trying to figure out how the original (2004) fasteners are removed and reinstalled… Do you mind explaining the process? It would be greatly appreciated.
09-12-2023, 09:16 AM
Hey JRO, the ones used by SMB are simply push in panel pins that have "fins" on the shaft that hold the pins in place. Just gently pry them out by inserting a thin metal edge underneath the cap (I may have used a putty knife). I ended up breaking about 1/2 dozen or so, but my local hardware store carried almost the exact same replacements. To avoid having the pins poke the rubber gasket on the backside it looks like SMB cut the excess off each pin from the backside after they were installed.
2001 Sportsmobile RB50 7.3
West Central Mountains, Idaho
09-12-2023, 09:40 AM
There are tools to remove those fasteners, sometimes called Christmas Tree fasteners.
https://www.amazon.com/s?k=auto+trim..._ts-doa-p_1_10
As mentioned a putty knife or similar tool will also work.
09-12-2023, 12:41 PM
What hardware store brand ? Where to be found ?
09-12-2023, 12:43 PM
Freeagent -- got a part number for their sight ? Thanks --
09-15-2023, 06:06 PM
I’m surprised these fastener is so simple, effective and have such longevity. Mine is a 2004 penthouse that needs repainting. All of them are solid after 15 years of snow, rain, heat, sun and lack of maintenance.
2004 Chevy G3500 EXT 6.0L QUIGLEY 4X4 IFS, Sportsmobile Penthouse.
09-24-2023, 05:49 PM
#20
Sorry it took so long to reply Doublevan, got mine at an independently owned hardware store supported by Do It Best Hardware. Would guess that most hardware or auto parts suppliers would carry very similar products. When I replaced mine it sure seemed that if more than a few were needed, purchasing through SMB would have been more cost effective. I can’t remember exactly which size I purchased, so would recommend taking in your own to compare with those in the store.
