I’m not quite sure how sportsmobile installed there Fiamma awning on the Ford Econolines. I was hoping for some detailed pictures of the mounting locations. Anyone out there who can help? It would be greatly appreciated.
I believe they used mounts through the body. If you want to install an awning on an E-Series van, suggest you contact 1der for his gutter mounts. See this thread: https://www.sportsmobileforum.com/fo...tch-16967.html
Chris
On my van they installed it poorly.The fix is going to require interior demolition. The method appears to be well nuts into the sheetmetal with no backing.
