I can adapt my 50'-0", 10/3 shore power line to a 20A receptacle right next to my meter and run the A/C with a 2.5 vac voltage drop. That takes me down to 117.5 vac at the load. I find that to be in the acceptable range. If all that's engaged is the A/C and the power converter/charger with no other 12vdc/110vac loads I don't have a problem. This is, of course, what occurs in my driveway. The results for others may vary.
'07 GMC 2500 6.0
