The older the rubber brake lines are, the bigger the improvement when you replace them. You also get what you pay for, buy the highest quality lines you can afford. Cheap lines can feel squishy right out of the box. Because the length of the rubber part of the brake lines is fairly short you probably will see some, but not a huge improvement with new rubber lines. The braided steel ones are tougher, look cooler and will "feel" like new high quality lines much longer.
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
