There are only 3 different pitman arms used on the Eseries, one of which wasn't used until 2019-ish.
The other two were common between '92 to ~2003 (give or take). After 2004-ish, I've only seen one.
32-spline Pitman arm (MOOG K80783, big spline clocked 45deg), '92~'03
36-spline Pitman arm (MOOG K80785, big spline inline with arm), '04+
All of the E-series pitman arms are 5.2" center to center.
There are a number of other pitman arms that will fit an E-series steering gear that came from other applications (like an Fseries Truck) but there's no way of knowing what it is without a part number (engineering part numbers can be cross-referenced by people in the know at a Ford parts counter) or what the measurements are or both.
Chances are, you have a stock pitman arm.
