Originally Posted by olivelawn
Or maybe it is? Most pictures I've seen seem to have a shorter rubber seal. Hard for me to be sure.
That's the oil seal with an integral dust boot. When I replaced mine a parts search at the local auto parts store kept coming up with a seal without the larger boot. It would have fit, but I preferred the added protection of the original style and finally found a number on the original one that identified it. As for your noise, the muffler on mine had something come loose inside, and would make a random rattling noise, and smacking it with a mallet identified the source. As for your oil leak, it doesn't look too serious and as long as you don't let it run out of oil, you could go for years like that, but if that oil is soaking into the transmission mount rubber it can degrade it. Good luck.............
