Originally Posted by carringb
The rear end being off-center should not cause handling problems.
Not Necessarily True!
With the rear-end being off-center side to side you are assuming the rear-end is still mounted parallel with the front axle. That may not be true as the van may be "Crabbing" going down the road crooked with a bent or misaligned rear axle/suspension, a bent chassis, bent leaf springs or shackles, worn out leaf spring bushings and you may not know it!
I suggest the owner of the van have someone drive his van with him following behind the van in another vehicle to see if the van is visibly "Crabbing" going down the road. It can be very obvious with even the slightest rear-end misalignment if your vehicle is "Crabbing" while driving down the road as the van body will look like the van body is crooked right or left driving in the lane when following.
This rear-end side to side misalignment issue could very easily be do to something BENT in the rear end assembly, rear suspension or the vehicle chassis. The rear-end should be square to the body side to side and parallel to the front axle.
Raising or lowering a coil spring front axle/suspension that includes a track bar for centering the front axle will change the center location side to side of the front axle if you do not measure and adjust the track bar as needed based upon the suspension height change. Question? Is the front suspension square side to side and parallel to the rear axle in your van? Better look and measure!
You can also measure the rear-end mounting points to the rear axle, leaf spring to chassis mounting points and look at the bushings in the rear leaf springs to see if they are all still good. Also check the rear axle U bolts are tight and make sure the rear-end is properly seated in the leaf spring perches.
Time to find somebody that knows what they are doing and get the tape measure out to find the real source of your higher speed steering issues starting at the rear-end!
