Resurrecting this for some help.
I actually located the details of the van I purchased used. As it turns out, the prior owner had Yakima rails installed. No big deal - they're all about the same, right?
So I ordered a nice set of Rhino Racks at a good price with multiple fit kits. I thought that was a great bonus. Those racks arrived last weekend and look top notch.
Today I went to install them. Should be simple, right? Remove the end cap at the rear, slide the square nuts into the rails, position, tighten, etc. Sadly, the first step was a failure. The screws holding the endcap in place just spin. Not freely - they're clearly well sealed in there, but they don't grab anything enough to back out. Then I notice that the rails all have round headed screws in them instead of recessed. So even if I can get these caps off, I can't slide the nuts past the next screw. I'm not inclined to remove these and introduce the possibility of leaks.
Is this unique to my van? Did the installed mess up both the rails, in terms of the screws, and the workmanship in that the endcap is screwed into nothing?
Anyone else have to struggle through what should have been a simple rack install? What are some creative options I may not have considered?
Thanks in advance!
