Old 11-07-2021, 08:21 AM   #1
Transfer Flow 46 Gal Tank Question
Adding a diesel furnace to my Ď06 E350 6.0 EB. It has the TF 46 gallon tank.
Looking for a tank removal video but all Iím seeing are vids for the pickup. Anyone know if the fuel tanks are the same between van and pickup?
'06 E350 6.0 PSD EB-50 4x4
'02 Eurovan Weekender
'04 KTM 525 EXC
'12 SkiDoo Summit ETEC 800
'72 Baja Bug
GunniLuv is offline   Reply With Quote
Old 11-07-2021, 08:53 AM   #2
REF
REF's Avatar
Send a message via MSN to REF
The 46 Transfer flow tank is not stock, but pretty straight forward to drop, 2 straps holding it up, Itís best to run your fuel as low as you can, even when the low fuel light goes on, thereís still a good amount left in the tank, maybe 5 gal in my case. There was an extra port already drilled out that was covered with a plate or a rubber plug that I was able to use for the new heater pickup.
Old 11-07-2021, 09:13 AM   #3
1der's Avatar
While your tank is out, consider doing the "harpoon" and other modifications to improve the venting and usable capacity, if not already done. The TF46 van tank typically has ~41 gals usable since it does not fill the top ~10% of the tank due to venting restrictions.
Lots of threads here on SMBforum re: TF tank issues, mods.
As REF suggested, drain the tank as much as possible before removing. Running the heater fuel pickup tube to within an 1/8 - 1/4" of the bottom of the tank is absolutely the right call.
The TF46 tank is a proprietary design shared by Quadvan and SMB. I doubt the pickup snd van tanks are the same.
Beastie 3: 2002 7.3 EB Cargo: Agile TTB, CCV Mid Top, Custom Walk Through, Lots of stuff added. BlingMyRig.com
Old 11-07-2021, 09:50 AM   #4
1der and Ref, thank you so much!! Contemplating trying to do a video of my effort.
Iíve read a few threads saying itís best to just cut the straps and replace them. Is that sound advice?
I love this forum.
'04 KTM 525 EXC
'72 Baja Bug
Old 11-07-2021, 10:58 AM   #5
REF
REF's Avatar
We were able to reuse the straps, mostly out of time constraints of sourcing material and making new ones, although I was keen on replacing them, they were still fine.
Old 11-07-2021, 12:46 PM   #6
Twoxentrix's Avatar
I reused the straps as well (nothing wrong with them), but replaced all the hardware with new, and put new rubber between the straps & tank.
Coddiwomple
Rpence
Beatrice
Drizzt
