Old 02-28-2019, 08:53 AM   #11
Generic OBD2 scanners won't read brake system codes. But most tires shops have a scanner that will do it. If you already have a relationship with one, they probably won't charge you.
Old 02-28-2019, 09:03 AM   #12
KyleC's Avatar
Originally Posted by 86Scotty View Post
Pull one of your wheels and you will see a wiring harness going from the frame to the rotor. The only other thing coming from the frame to the hub is the brake hose/line so it's easy to spot.
Not quite the same as the van but basically this:
https://knoxville.craigslist.org/ctd...829743847.html
This was a link to an expired/deleted Craigslist ad
KyleC is offline   Reply With Quote
Old 03-01-2019, 02:58 PM   #13
KyleC's Avatar
Do y'all know if the code will be stored or if it is something that has to be on to be found? It's happened a couple of times since I bought it. Sometimes it's both the traction control and abs. But other times it's just the ABS
Old 03-03-2019, 07:51 AM   #14
If a DTC was triggered it will be in the PCM's memory unless someone has cleared all codes including the ABS DTC's.
If you plug in a scanner that'll read ABS DTC's it will show up whether the dash lamp is lit or not.
Old 03-03-2019, 07:58 AM   #15
Oops, misfire on copy/paste there. What I did was this. Go to Youtube, search for Ford ABS sensor replacement, enjoy results.
Old 03-08-2019, 09:16 PM   #16
lchukar's Avatar
My 2010 Ford SMB almost always gets the ABS light on when I drive on seriously dusty roads. Not me gravel roads, but deep dusty one. Then it always clears up once we hit the highway.
lchukar is offline   Reply With Quote
