Old 11-03-2024, 08:02 AM   #1
Upgraded springs but keep stock height in front
Moog Coils for front and shock recommendations
2002 E350, 5.4, 2wd, stock suspension, do NOT want a lift when done with new coil, fiberglass high top, 265/70r/17 KO2s, minor fender cutting already done.
I am just looking to decrease the body roll some and replace the shocks. Also, increase ride quality would be a bonus. Mostly body roll is my main issue.
It already has sway bars front and rear.
I have been searching but it seems most everyone wants to also get a lift out of their replacements. I have read CC880S, C880S, CC880 and blah blah blah.
Just want a drop in replacement. Keep stock height as I want it level, as it is now, and don't want to get into the rear and replacing those leaves nor would I ever add blocks.
Any help?
cencal is offline   Reply With Quote
Old 11-03-2024, 08:34 AM   #2
Start with quality shock first, might be enough and they're on your list anyways.
Do you know your spring code? I'm not sure there is a stock height spring with an increased spring rate, that would usually result in an increase in height.
Maybe you could get a stiffer spring (one you mentioned above) and heat the coils some to drop it to your desire height? That used to be a common way to lower a vehicle, before they made drop springs for it.
kbeefy is offline   Reply With Quote
Old 11-03-2024, 08:55 AM   #3
1der's Avatar
What is the condition of all the sway bar bushings?
Old 11-03-2024, 11:11 AM   #4
Twoxentrix's Avatar
Couple bolt on options since you already have front & rear sway bars:
First - What size sway bars do you have? Going to a larger diameter will help the keep the van more level through cornering:
https://www.etrailer.com/swaybars-2002_Ford_Van.htm
Coil over shocks could add additional support (if you don't require a lot of wheel articulation), Just an example:
https://www.shockwarehouse.com/produ...CABEgI1hfD_BwE
Sumo bump stops and/or coil supports , add a leaf, and several other options listed here (just scroll through the different options on the second link attached below to see if any fit your budget and/or purpose):
https://www.etrailer.com/Vehicle-Sus...ID=20024042853
https://www.etrailer.com/susp-2002_Ford_Van.htm
https://superspringsinternational.com/coil-sumosprings/
https://superspringsinternational.com/sumosprings/
https://activesuspension.com/product...-van-1973-2007
Old 11-03-2024, 12:16 PM   #5
#1 update you can do is swap in a 2008+ front axle. This gets rid of the through-axle sway-bar bushing which always develops slop and allows body roll before the sway bar even engages. If that’s not feasible right now, the moog poly bushings are a good compromise. But definitely consider it id you ever need new ball joints or new brakes. The cost of doing the axle swap is less than doing both of those repairs.
Monotube shocks will do the most for ride quality.
Old 11-07-2024, 11:36 AM   #6
Kibo's Avatar
I assume you're talking about 4WD? OP has a 2WD.
Old 11-07-2024, 12:15 PM   #7
How heavy is your front end? We have a fibreglass roof as well and the front axle weighs 1,560kg (~3,400lbs). Based on the front end weight, we replaced our stock springs (2002 E250 5.4L) with springs for the 7.3L diesel which has a similar weight to our 5.4L with fiberglass top.
We used NAPA springs 277-5474 (because I needed them locally last minute) but it's the same spring rate as the Moog CC81366. (The 880 and 880S series are for the previous generation vans. I think the CC81366 are similar to the 880's.)
Now, you said you don't want to lift it but if you're on stock springs with a fibreglass top you're probably running lower than stock. I can't remember the dimensions off the top of my head but with the diesel springs on our build, the height is stock again. We added some new Bilsteins at the same time and between the springs and shocks the ride was greatly improved with reduced roll.
kevman is offline   Reply With Quote
Old 11-07-2024, 12:36 PM   #8
I think he's referring to the beams.
Old 11-07-2024, 12:53 PM   #9
Kibo's Avatar
I think my brain was just hung up on the word "axle".
My van was already Quiglified when I bought it, so I'm not intimately familiar with the 2WD setup. Genuinely curious, does swapping the beams allow one to change the swaybar configuration? I've seen swaybars that go through the frame rails, vs. my configuration that has them clamped with bushings to the underside of the frame rails.
Old 11-08-2024, 05:59 AM   #10
The 2WD vans have a front axle too. So too all cars….
Yes, I was referring to the 2WD axle. The sway bars end on the 2008+ vans use actual end-links. All E-series sway-bars are mounted to the underside of the frame rails.
