Old 08-02-2020, 03:28 PM   #31
AKSeeker's Avatar
Thanks Jack K, good idea! I have been searching unsuccessfully (and buying, unfortunately) a number of different padlocks in an attempt to find one with a long enough shank and wide enough spacing to fit between the two Aluminess swing arm holes. In the meantime, have been using a bicycle cable to lock the two together, but I like your solution!
'06 Ford 6.0 PSD E350 4x4 RB50 Customized SMB w/penthouse, Aluminess Bumpers & roof playpen. All Diesel & Electric: Espar Hydronic Heat, Wallas Catalytic Hot Plate Stove, VitriFrigo 12v Fridge, Dieselsite & Amsoil Filtration,.. and my other RV is a BMW R1200GS.
AKSeeker is offline   Reply With Quote
Old 08-02-2020, 03:33 PM   #32
AKSeeker's Avatar
Originally Posted by vandiesel View Post
That is sweet. You have a lot to get through to get the gun while the bear or tweaker is coming at you. I picture a movie scene.
Thanks vandiesel, but like I said, "that's just the backup!"
Old 08-02-2020, 03:59 PM   #33
Twoxentrix's Avatar
I too have been concerned with the Aluminess latch releasing at in inopportune time, but also the easy of opening the swing arms to get to the doors if there is no safety type lock keeping them together. My swing-arm pinholes are off alignment by about 1/2", so I had to find a lock of sorts that would work...am now using a Bulldog Adjustable Trailer Coupler Lock. Nice part is when its on its not easy to access. so that in-itself is a slight deterrent. I attach with the locking cylinder below the swing arm hole.
https://www.amazon.com/Bulldog-58041...404544&sr=8-14
If the holes align, something along these lines could be used:
https://www.amazon.com/Master-Lock-1...404544&sr=8-86
Old 08-03-2020, 07:24 AM   #34
JohnandMandi's Avatar
We ordered a set of 12 American Locks all keyed the same for all outside and inside needs. Not sure the exact length, but we have been using one for our swing arms for 5 years. Do duct tape over the keyholes and lube them every quarter.
https://americanlocks.com/
2001 7.3 E350 Ujoint 4" w/ SMB Penthouse
johnandmandi.com
JohnandMandi is offline   Reply With Quote
