Old 09-02-2024, 09:17 AM   #1
Wanted 7.3l diesel e-350 Ac compressor bolt kit diagram
Looks like my arc compressor came loose and throw my serpentine bolt. Missing bolts and looking for a bolt kit. Looking for an exploded view of bolt location.
Matto is offline   Reply With Quote
Old 09-02-2024, 11:47 AM   #2
1der's Avatar
Year of your rig?
Old 09-02-2024, 04:58 PM   #3
2003. Have all components apart. Bolts sheared off that hold the ac bracket to motor. Looking for part numbers for those bolts. Also looking for part numbers for power steering vacuum pump to bracket bolts , ac compressor to bracket bolts, power steering pump to bracket bolts. Yesterday I lost power steering and brakes. Serpent belt was loose. Got it towed to a friends and found a loose ac compressor. Any help tracking part number would be greatly appreciated
Old 09-02-2024, 05:49 PM   #4
1der's Avatar
I'll see what I can find in my 2002 Factory manuals. One more question - one or two alternators?
Old 09-02-2024, 07:12 PM   #5
One relocated to bottom passenger side.
Old 09-03-2024, 12:13 PM   #6
1der's Avatar
No luck in the manuals re bolt p/n's. Perhaps a salvage yard visit?? Where are you located?
Old 09-03-2024, 01:20 PM   #7
Twoxentrix's Avatar
If you called a Dealership’s Parts Dept would they not be able to provide you this info? If you brought it to them to fix I suspect they would end out looking up the part numbers anyway.
Old 09-03-2024, 02:33 PM   #8
Research all morning. Had the bracket part number so ford was able to get a part number for the bolts to hold the bracket to the block which I had no treads to figure out the size. Part number came back 3/8 16 x 5.5 . All components that bolt to the bracket are M8 so that part was easy. Now the hard part. Getting the snapped bolts out. Thanks
Clyde
ormtnbiker
TumbleWeed
Sarah
