Originally Posted by Justgosurfin
Maybe making the headliner panel with a cutout for the padded blocks so it can come down without removing them?
I’m at fan, light strips, solar at some point and backup camera so far but I’m
If you make cut-outs for the padded blocks then you'll need screws around the perimeter of the headliner to hold it up....
My headliner is held in place by the padded blocks only ......no other exposed screw heads.
I used the SMB plastic panel joiner thing in the middle of my headliner; if I was doing it again I would place the headliner seam under one of the padded blocks. I'm pretty sure member scalf77 did his headliner this way. This way you only have the plastic panel joiner on either side of the padded blocks...looks very clean.
Run sufficient gauge solar wire the first time....don't ask me how I know this.....PITA.
If I were doing my headliner again I would also ditch the rectangular ceiling lights and put LED lights on the padded blocks.....much more updated look.
