-   -   Identifying limited slip diff. & gear ratio? (https://www.sportsmobileforum.com/forums/f33/identifying-limited-slip-diff-and-gear-ratio-11253.html)
Trent4444 11-04-2013 04:03 PM
If one was looking to purchase an "experienced" Ford E-250 or 350 Sportsmobile [ I am ] is there a way to determine if it has a limited slip differential [without driving it] and the gear ratio? Markings, placards, stamped numbers, etc?
Trent
my3kids 11-04-2013 05:30 PM
Re: Identifying limited slip diff. & gear ratio?
Trent,
Look for the sticker on the driver door jamb. There you will find the axle, ratio, limited slip or not, engine, transmission, color and a couple of other items not usually revealed by the VIN.
Armed with this you'll need a decoder ring found for that year's shop manual. The decoding pages are in the first section of the shop manual. The decoding info may be available elsewhere but I have never been able to locate it outside of the shop manual.
Hope this helps™,
