-   -   Transit updates from SMB? (https://www.sportsmobileforum.com/forums/f9/transit-updates-from-smb-11941.html)
BroncoHauler 02-15-2014 12:17 PM
Re: Transit updates from SMB?
I'm an engineer, so I tend to over analyze things, but when it comes to vehicles and their engines, my primary decision maker is seat-of-the-pants. I need to drive it (hopefully while towing too) and see if I like how it drives in terms of power, shift-points, RPMs. Fuel usage is important, but it's a secondary consideration.
Chance 02-15-2014 01:47 PM
I get that, but everything else being equal we all want improved fuel economy.
One of the least expensive ways to reduce fuel consumption is to reduce engine displacement (to a point). Otherwise, in my opinion, the new Transit would likely have a 6.8L V10 or similar instead of a base engine nearly half that size. The new goal seems to be getting more power and torque out of smaller engines so driving experience is not compromised too much. I think that's what Eco-Boost tries to do. But it comes at a cost, and the question was whether it would save enough to pay for itself.
Chance 02-17-2014 12:27 PM
The fuel-economy comparison between naturally aspirated (NA) versus Eco-Boost (EB) engines interested me on both practical and technical levels, so I looked a little deeper to see if what Ford estimated from the study mentioned above materialized or not.
In any case fuel economy differences seem small. When same/similar size engine is "boosted" (which then makes more power), MPGs go down slightly in EPA ratings like we see for F-150 (3.7L NA versus 3.5 EB).
However, if EcoBoost engine is downsized in displacement so it has similar power and torque as its naturally-aspirated counterpart, then MPGs could go up slightly. This can be seen on Transit Connect with 2.5L NA I-4 (rated 169 HP and 171 lb-ft) which gets 21/29 MPG versus 1.6L EcoBoost I-4 (rated 178 HP and 184 lb-ft) which is rated slightly better at 22/30 MPG by EPA for same model.
Chance 02-23-2014 05:40 PM
As some may have noticed from different sources, additional information for the new Transit continues to roll out slowly. I'm updating info in the OP because part of it has been revised.
Std V6 -
266 HP at 6500 RPM
249 lb-ft at 4000 RPM
Eco-Boost -
300 HP at 5000 RPM
400 lb-ft at 2500 RPM
3.2L Diesel -
190 HP at 3000 RPM
346 lb-ft at 1500 RPM
It seems the EB engine option was revised down to 300 HP.
Several buyers' guides have listed ordering information, and a couple of them have preliminary data suggesting the new Transit won't be anywhere as capable as the Econoline when it comes to towing. As an example, a T-250 3.7L V6 with a 9,000 GVWR had a GCWR of only 10,800 pounds. Tow ratings thus far, depending on van size/model, range from 4800 to 5300 pounds.
I'm hoping this information is not accurate because the GCWR is actually lower than the FWD ProMaster with gasoline engine. That van has a rating of 11,500 pound GCWR.
If any of you have additional information on Transit capabilities and/or ratings, please share.
pffan1990 02-27-2014 05:21 PM
Well I can understand Ford's reasoning for the derating of their engines for the Transit but why on Earth are the tow rating so dismal? The current and outdated Econoline can tow twice the amount of the average 5,000-pound Transit rating. I know it's unibody and all, but still. Like Chance mentioned, the Promaster's GVWR is higher... as is the Sprinter. Perhaps Ford is waiting until right before sale date to all of a sudden announce increased GVWR figures? As they did with the diesel power rating a few years ago?
I saw some other websites with pricing info and was quite pleased to see some options on the cargo. One of which is the actual factory spray-on floor lining! Kudos, Ford! I like how on the Wagon, the RV-prep package can be ordered without any back seats for the owner's own customization. There are more but most has already been said elsewhere in this thread. I'm actually looking forward to this Transit as well as SMB's offering.
carringb 02-27-2014 06:24 PM
I suspect there's some marketing rational in there.... The diesel and EcoBoost will no doubt be rated higher, and they have to keep the standard motor rated lower to nudge buyers towards the more expensive/ more profitable (for Ford) motors.
Chance 02-27-2014 08:17 PM
Regarding the low tow ratings, which are not official yet as far as I know, I think two factors could be making a considerable difference relative to Econoline.
As mentioned above, a light weight unitized structure makes it difficult to attach a heavy load like a receiver to what is not much more than thick sheet metal. Some Sprinters may go up to 7500 lbs but most are limited to the same 5000-pound range.
The second big difference may be that starting with 2015 models, Ford is "reportedly" going to rate towing capacity based on SAE Standard J2807. If so, other factors beyond power or structural strength may limit tow capacity. The new standard should be interesting to follow since different brands and models will be rated on same basis.
pffan1990 02-27-2014 08:41 PM
Bingo! I will have to stand corrected here once you mentioned the new J2807 standards. I had completely forgotten about that. Now that you mentioned it, Ford has said they would switch to that in 2015 starting with the F-150, so I am sure the Transit would switch to that as well. I never even thought about that and it does make sense considering the new standards does significantly reduce tow ratings compared to the current standards. Glad you brought this up.
pffan1990 09-08-2014 09:07 PM
Whoa! The page of the Transit on Sportsmobile site has been updated just a few days ago. It now includes the pdf sheets for basic info. All is basically there except a few pricing info that are listed as 'TBD'. Also, the MSRP pricing for the Transit has been left blank so I guess they didn't know at the time of making the pdf files. But it's so nice seeing the page updated. I can't wait to see the actual Transit floor plans and pictures when they get them ready!!
https://www.sportsmobile.com/1a_tr_vaninfo.html
moorefc 10-05-2014 01:49 PM
Looks like the prices are posted....a little confusing if the mid length comes in a low roof option, but prices are there...bout the same as E series...
